Home > Technical (L322) > Help now please - Hard battery reset - How ?
Page 2 of 3 <123>
Go Beyond
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
Thank you, I hope so Confused
Post #262633 1st Jun 2014 5:43pm
Go Beyond
Left overnight and still frozen display Sad
Any ideas ?
Post #262704 2nd Jun 2014 6:31am
hmmm, that didnt work then....is your battery fully charged and holding its charge? the ecus on the FF are very voltage sensitive and this could be the reason for your problem.. ... - .- -.
Post #262707 2nd Jun 2014 6:47am
Go Beyond
Hi Stan,
Yes, battery is in really good condition, holding charge, no problem there.
This has only occurred since disconnecting / reconnecting battery.
I've checked boot and there is no water ingress.
Worth disconnecting battery again ?
Post #262709 2nd Jun 2014 6:50am
i would .. ... - .- -.
Post #262711 2nd Jun 2014 6:59am
Go Beyond
Followed the procedure in WIKI to the letter and still I have a frozen screen !!!
What do I do now ???
Post #262797 2nd Jun 2014 4:29pm
this is from the wiki,
http://www.fullfatrr.com/forum/post248527.html#248527 ... - .- -.
Post #262821 2nd Jun 2014 6:10pm
Go Beyond
Yes, thank you, already tried that and it hasn't worked
Post #262822 2nd Jun 2014 6:12pm
Andy B
Anyone else in the Kent area that can help Go Beyond out with an IID tool (2005 RR)?
It will cost a few quid to register another VIN, but suspect there is an ECU fault that needs clearing SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #262825 2nd Jun 2014 6:32pm
Go Beyond
Bow down
Post #262831 2nd Jun 2014 7:05pm
Go Beyond
Sussed it !!!! Very Happy
Post #262838 2nd Jun 2014 7:36pm
Andy B
Woo hoo! Great news mate, howdya fixit? Thumbs Up Smile SDV8 AB MY 2019
Post #262939 3rd Jun 2014 7:03am
Go Beyond
Basically as Stan's link but it wasn't the Blue Tooth unit that wasn't allowing the infrared signal through, it was the TMC unit.
Disconnected the two infrared cables and patched them together using the biro tube trick and bingo !
For anyone else that has this problem note that if you have the engine running and then start patching the infrared cables together and you hit on the correct one then the stereo will instantly burst into life which makes it a lot easier if you are doing it on your own.
What does the TMC box actually do ???
Post #262940 3rd Jun 2014 7:11am
Andy B
Great news, glad the biro trick worked. Thumbs Up TMC delivers traffic and travel info to the Sat Nav system using a digitally coded system via the Radio Data System or RDS. So live updates basically.
Cheers,
Andy SDV8 AB MY 2019
Post #262942 3rd Jun 2014 7:25am
Go Beyond
Cheers Andy, I won't rush to replace that then
Post #262944 3rd Jun 2014 7:29am
Page 2 of 3 <123>
