Home > Maintenance & Mods (L322) > Torque converter ??? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Torque converter is screaming at me, sounds like a strangled bird in there, at least I presume it is, does it when it gets hot and does it in drive and neutral when stopped...
31st May 2014 6:23am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
Remanufacturing the Sachs W260S-2GWK torque converter is a specialist task : http://www.fullfatrr.com/forum/post186323.html#186323
31st May 2014 9:45am |
Thanks Phil I'll ring them... Pete
31st May 2014 9:55am |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
I used Sussex Auto Parts last month for my TC after seeing RRPhil recommend them in another post (thanks RRPhil ).
31st May 2014 10:25am |
Thanks chaps,
31st May 2014 10:37am |
Updated transmission removal procedure (not as per the workshop manual), see post no 45 (by RRPhil again ):
31st May 2014 10:38am |
If the water pump is sounding that bad it's probably on it's last legs and the bearing is shot.
31st May 2014 10:47am |
Cheers, I've ordered a new pump, belts and coolant and I'll take it home when I finish work, only 7 miles and it can have a rest and I'll get the Sunday car out till it's done.... Pete
31st May 2014 11:11am |
Well it got 3 miles home and it's seized and shredded the fan belt, now waiting for the recovery truck
31st May 2014 12:57pm |
Yep, think that's knackered.....
31st May 2014 6:21pm |
Think might need a bit of gaffer tape to sort out the drive belt as well
31st May 2014 7:36pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
31st May 2014 7:51pm |
Unlucky, Sods Law! I would have done the same for sake of 7 miles.
31st May 2014 7:58pm |
