![]() | Home > Maintenance & Mods (L322) > supercharged l322 radiator removal without movin viscous fan |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Not a good day then, hope it gets sorted soon for you... Pete
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
iansweetman Member Since: 18 May 2013 Location: wales Posts: 17 ![]() ![]() |
Quick question guys I bought 10 litres of concentrated coolant from euro car parts bit overkill I know but ill have some spare! Is it okay to use on the supercharged engine as a friend advised had to be pink coolant due to engine being ally? Mine is purple so will be ok to use when diluted down with water will look pink I imagine so does it have the chemicals to stop ruating engine as my friend mentioned or is he pulling my leg!
I'm not a specialist on this (my coolers on the 4.2 got F. U. C. K. E. D due to idiots putting pure water in) but I understand that any coolant that is suitable for alu engines will do, HOWEVER, mixing the LR (apparently biodegradable) coolant with the normal (usually green) coolant, can result in sludge forming or so I have been told.
The antifreeze type is critical... If you want a head gasket in 2 yrs |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1352 ![]() ![]() |
as long as your using OAT grade antifreeze , it will be okay to use |
This is the concentrated antifreeze ive got is this suitable?
Yes
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Unless you know you are in a soft tap water area dilute OAT with de-ionised water. If you put crap water in with it you might as well not bother using it as it wipes out the benefits. |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
Did you manage to get the rad out without discharging the air con? 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
Yes but got another headache now leaking rad sorted seems have another leak coming from water pump so will have to tackle that as well!
You will need two skinny fan spanners 32mm (Halfords do them - but they are only just long enough! - they also do a 32mm combination spanner which is longer) if it is on there tight, and it undoes the wrong way - clockwise. What a bummer to have done the clever bit and now having to take it all apart again.
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
Normal right hand thread I believe on a SC.
I have bought the fan tools but im not doing it in the wet myself so my local specialist which happens to be my friend is going to do it for me!
