Home > Maintenance & Mods (L322) > Gearbox issue
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Gearbox issue
Had car back a week but got a vibration at around 1800rpm and you can feel it through the floor and car, you can do it in gear with brake on as well which makes me think it's the torque converter out of balance a bit, any thoughts before I go back he's a good chap so no probs but just like a little ammo thanks _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #262080 29th May 2014 11:25am
Scottyav
brand new converter today and its 100% perfect again, Neil Smith is the top box man in the Midlands trust me and most of the uk so well worth the travel for people, im lucky he's 5 mins from me Thumbs Up
Neil Smith
Cannock staffs
01543 505599 _____________________________________________________
Post #263452 5th Jun 2014 5:21pm
thats good that its now sorted... Thumbs Up ... - .- -.
Post #263464 5th Jun 2014 7:01pm
Dolphinboy
Scotty, how much was it all in?
Post #274221 4th Aug 2014 11:27am
Scottyav
£1400 all in can't feel a gear change at all so smooth it's like driving my mates 10 plate Smile _____________________________________________________
Post #275425 12th Aug 2014 9:02am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Shocked Now that's a good price, I've seen threads of gearbox/ torque converter changes up to 3k!
What mileage did the original one do before problems started? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #275456 12th Aug 2014 12:17pm
RRPhil
It may be worth emphasising that there’s a huge difference between a transmission rebuild and just replacing the torque converter. There’s no need to open up the transmission to replace the torque converter and therefore no specialist knowledge is required - any competent mechanic should be able to do it. The book time for the whole job is around 5 hours. Once the transmission is on the floor the torque converter simply slides off its splines and the new one slides on in its place – a very quick swap. A (high quality) remanufactured torque converter costs around the £250 mark.
Clearly the transmission fluid would have to be replaced at the same time, and it’s a good opportunity to replace the filter too. When I had mine done (ZF not GM) the total cost would have been under £700 (workshop rate was around £55/hour) but I also had to have the oil cooler pipes replaced (due to corrosion) which added another £100 or so to the bill.
Phil
Post #275601 13th Aug 2014 9:49am
Scottyav
140k it was on and took him 5days it was the splines that were stripped on a few gears so the whole kaboodle was changed including solenoids Wink I've known him 20 years and sent many boxes to him when we had the car pitch and always been good and fair. _____________________________________________________
Post #275626 13th Aug 2014 12:28pm
