Home > Maintenance & Mods (L322) > IID Question
RR2008HSE
IID Question
I had a check engine light the other day. Code reader has one of the catalysts was below "threshold efficiency". Quick google search said this often happens with a dirty throttle body (Jag 4.4 NA) and I had other symptoms that pointed to the TB. I had my indie clean the TB and it's running sweetly. He told me that, if that doesn't solve the problem, that the O2 sensors might have lost their proper values and that the "car would need to be reflashed". I'm not entirely sure what he meant, but he said only the JLR dealer can do it. So, can we "reflash" with the IID? If the answer is "yes", my supplementary question is, "how?"
Much thanks in advance. Bow down
Post #261597 26th May 2014 11:50pm
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Hi
It depends on the state of the O2 sensor itself:
-If its in good condition, re-flashing the Engine ECU with an improved firmware version might help. This is not supported by the IIDTool at the moment but it will be in time.
-If the O2 sensor is not working properly, re-flashing the ECU wont solve the problem. In this case, the sensor would have to be replaced and the engine adaption cleared (can be done with an IIDTool)
Cheers
Post #261656 27th May 2014 1:34pm
SteveMFr
Site Sponsor
To be clear - I think your mech does not have his terminology straight. When he says re-flash, he likely means clearing the adaptive values (taken from the context of what you write).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #261673 27th May 2014 4:09pm
PatGAPInnov
Site Sponsor
Post #261886 28th May 2014 2:53pm
RR2008HSE
Much thanks. Info appreciated. Bow down I'll stay tuned as it looks like nice updates will be coming.
Post #262391 31st May 2014 12:57am
