Home > Technical (L322) > oils ???
lee58uk
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
oils ???
Hi I have just joined the club and brought a 2006 RR SC with 68k. It come with a BRC LPG kit fitted and runs great.
the last owner who brought it new had a land rover service history done up to 44k and can not prove the next service so i knocked him down to 11800.
So i have change engine oil and filter, pollen filter, Air filter, both diff oils, break fluid, and will be doing the auto box filter and oil along with the steering fluid.
My question is should the auto box & PAS fluid be red oil or a yellow colour? when i check it seems most of the oils have to be a special blend, i assume this is due to seal for life ( Warranty).
the transfer box oil is going to be 50 pounds from the main stealer, is this a special oil also?
I will get some pics and upload, as i love this RR
regards
Lee
Post #261511 26th May 2014 5:54pm
Not sure on the colour, but the auto box oil is quite specific. NEEDS to be the right ZF fluid/LR fluid, the transfer box also needs to be the right 'special' fluid from landrover, so do the diffs though they are a branded oil. There is nothing that can't be fixed with a hammer😜😜
Post #261561 26th May 2014 8:53pm
RRPhil
Only use ZF Lifeguard Fluid 6 in your 6HP26
Phil
Post #261576 26th May 2014 10:12pm
What are the other two Phil?
Post #261585 26th May 2014 11:07pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
I think it's......
1) GM 5 speed in TD6
2) ZF 5 speed in BMW 4.4V8
3) ZF 6 speed in AJV8 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #261588 26th May 2014 11:24pm
Ahh, not seen them in non OE bottles before Thumbs Up
Thought they may have been different grades/prices for his SC oil...
Post #261589 26th May 2014 11:28pm
lee58uk
Blimey Pictures as well 10/10!!
the power steering oil looked a dirty gold colour so i will assume its not just ATF.
thanks a lot guys!
Post #261608 27th May 2014 8:25am
