![]() | Home > Maintenance & Mods (L322) > Newbie. Bit of help needed please |
Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675 ![]() ![]() |
Have you tried turning the steering all the way to the left and all the way to the right, you normally need to do this if you disconnect the battery to correct the suspension fault.
Check out this post for info on changing the VentureCam battery.
MikeT Member Since: 19 May 2014 Location: Moscow Posts: 87 ![]() ![]() |
Thanks for the hints. Didn't know about turning the wheel. The thread about replacing the venture cam battery is very detailed
Ok so just tried to get rid of the suspension fault message after boosting my battery by following the advice but without success |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
did you disconnect the battery as per the wiki info?
Aahhh no didn't disconnect. Didn't see the wiki So it it disconnect then reconnect battery then move the steering wheel?
yep do that... |
Right then. S'pose I'll try again but do it properly this time |
Ok. So I finally got around to trying to sort out this suspension fault. I'll be honest ( and I feel a bit of a numpty). I struggled to follow the instructions exactly. Let me explain what I did....
They have B&Q in Russia? |
A place called OBI. their logo is the same colour orange as B&Q so I think it's the same |
Ah. I know OBI, they have them here in Switzerland. |
So Kurtz. Now we have finished discussing global retail. Is there anything I should be buying from B&Q or OBI ? (Other good DIY stores are available) |
Fork handles.
