Home > Maintenance & Mods (L322) > The compressor saga goes on !!!!
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Hi guys ,after the aldi offer wasn't available I'm still looking.im after something for my new garage .ive found one like this on the bay of flea for £200. Would this be suitable to change wheels and run air tools ,ie chisels cutting tool ,and sander and others .sorry to be a pain but I've done lots of reading and I only want to buy once .
ABAC Redline 100 Litre Compressor 230v
Home > Air Tools & Compressors > Compressors > Electric Compressors > 90 Litre Compressors > ABAC Redline 100 Litre Compressor 230v
Product Information
Powerful 3.0HP Motor
Wheel Kit and Regulator
Auto Stop-start Control
Manufactured in compliance with CE directive.
UK - NATIONWIDE BACK-UP AND DISTRIBUTION
CFM: 12
Ltr/min: 340
Bar: 9
PSI: 130
kW: 3
HP: 2.2
Volt: 230 13A
Ltrs: 100
https://www.discount-tools-uk.co.uk/image/...-100_W.jpg
At help again would be much appreciated.
Regards Tony
Post #260541 20th May 2014 5:26pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Hi Tony
I had loads of trouble sorting out a decent compressor - I found some of the smaller compressors come with tools they can't actually operate.
I bought in the end a 50L Draper V Twin 29355 compressor for about £240 and that operates all my stanley tools happily.
Discovered the key thing is to check the CFM (Air displacement) required for the specific tools you want and spec your compressor from there.
Even has a set of wheels you can actually use to move it around (unlike many where the wheels are a token gesture.
Hope that helps
Nick Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #261308 24th May 2014 11:12pm
Tony, i wouldn't think a 12cfm would remove a FFRR wheel nut? Let alone a set of 20 nuts! & at only 20ltrs capacity you would not run a tool for long before the cfm would be closer to 2!
You get what you pay for with compressors my friend... Sorry Thumbs Up
Post #261314 25th May 2014 12:23am
tony1kenobee
Many thanks guys.im now looking at a 14cfm compressor .hopefully it will do the job.got a few quid to spend so i might have to up my realities .cheers again
Post #261366 25th May 2014 1:28pm
^ What I advised a few weeks ago...
Remember you will need to use a 30 amp supply to run a 14CFM compressor, it won't run on a standard 15 amp circuit...or it will for a short while until the wires melt and cause a fire
Post #261373 25th May 2014 3:06pm
tony1kenobee
Thanks for the info.guess the wifey would be really miffed if I set fire to the garage.
Post #261441 26th May 2014 8:49am
Or the house "on route to the garage" Shocked Shocked Shocked Rolling Eyes Whistle
Post #261467 26th May 2014 10:53am
