Home > Maintenance & Mods (L322) > Door Panels |
Ian Donkin Member Since: 17 Aug 2010 Location: A Yorkshireman in Surrey Posts: 107 |
Probably a late answer for you now, but I did the drivers door in mine today for exactly the same reason...
21st Aug 2010 5:11pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
Paul ive had that problem i got round it by doing the following
21st Aug 2010 10:11pm |
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 |
not sure if this will help but thought I would post it check out this link http://www.rangerovers.net/repairdetails/d...trimcasing have to do mine at some stage good luck |
23rd Aug 2010 7:12am |
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 |
Thanks for your replies, I did entually get the gap right, I removed the lower window trim, and used a bit of brute force! Scarey at the time, but the end result was worth it!
11th Sep 2010 5:20pm |
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 |
Guys need your help. I want to replace the peeling window switch trim passenger side (uk) but before I start the removal do I need to disconnect the battery to stop air bags going off or air bag light ? any advice? Also is there an order to remove the plugs from inside the door card? |
12th Dec 2011 6:00pm |
12th Dec 2011 6:34pm |
thanks for the info Dan should help! |
14th Dec 2011 7:09pm |
