Home > Technical (L322) > l322 OE SIDE STEPS NOT WORKING
PUPPYDOGS
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
Hi, Just wondered if anyone can help me with my tdv8 which has oe side steps, the LH works perfectly but the RH stops out and only moves slightly when the door opens or closes.if I press the switch the RH will still not retract,the motor seems to be working so hubby says.
MANY THANKS JAYNE
Post #260576 20th May 2014 10:05pm
Mech stuck? Stone or stick wedged in somewhere?
Post #260578 20th May 2014 10:08pm
PUPPYDOGS
no nothing stuck checked already, hubby wondered if you can adjust the mechanism linkage ?
Post #260580 20th May 2014 10:12pm
