Home > Camping, Caravanning and Holidays > Towing with an Automatic |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 |
Just leave it in auto👍 it will do the business. I sometimes knock it into manual if it wont hold a gear on cruise control but otherwise just let the box sort it out.
18th May 2014 7:51pm |
iphs Member Since: 07 May 2014 Location: Norfolk Posts: 198 |
Sounds good to me. Ta. |
18th May 2014 7:56pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
one thing to bear in mind, on any autobox, there is a feature known as torque 'lock' this means that at a certain speed the 'flywheel' or torque converter, will no longer slip. this will be around 50mph on most cars. you will feel car stop slipping and any more (gentle) pedal down, will result in no more slippage, until you need to change-up, ie to stop it labouring. so, yes, drive it in 'D' but get used to feeling the 'lock-up, and then pressing a little harder. this will save you gearbox wear.
18th May 2014 10:07pm |
Cheers, I will read up on that. |
18th May 2014 10:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 |
I'm not a caravanist, but I'd imagine you'd need to manually select a lower gear and hold it whilst going down steep hills to stop the car trying to change up all the time and you having to hold it back on the brakes. 2011 Range Rover Vogue SE 4.4 TDV8
19th May 2014 5:45am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Been towing for 15 years, mainly twin axle caravans. Used a Disco 1 & 2, both manuals - but then had my first Auto; Discovery 3. Wondered why I hadn't bought an Auto before, though the D2 autobox was hateful.
19th May 2014 8:05am |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 |
Leave it in auto all the time.
19th May 2014 9:28am |
That seems to be the general advice. Good point about giving both the low and high range a workout though. |
19th May 2014 10:42am |
stevebrookman Member Since: 08 Jan 2010 Location: South Wales Posts: 50 |
Morning all,
21st May 2014 6:43am |
Mmmmm a manual Rover V8 SD1........ now how much can I buy a Vitesse for......?
21st May 2014 7:24am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 |
Just can't see the point of a manual gearbox, every other part of a modern car has been made to be easier to use or has become automatic, like lights and wipers etc...
21st May 2014 9:18am |
Also, get a big engine with lots of torque. Then the gearbox can stay in the lower gears more easily. So 5.0 SC or 4.4 TDV8 and leave it in auto all the time !! MY 2010 5.0 SC Galway green and sand interior!!
21st May 2014 11:37am |
peejay Member Since: 20 Sep 2013 Location: London / Kent borders Posts: 143 |
Please excuse my ignorance but why engage low range for manoeuvring ? I tow a twin axle caravan with my FF and I don't have any difficulties when parking up so why that advice?
28th May 2014 7:12pm |
Cos it gives slightly more control, eg will creep slower and move less for a given throttle input. There is nothing that can't be fixed with a hammer😜😜
28th May 2014 8:11pm |
