Home > Maintenance & Mods (L322) > Poll - does your L322 have rear wheel arch corrosion?
Have your L322 rear arches had corrosion?
yes, repaired by LR warranty
7%
 7%  [2]
yes, repaired by dealership goodwill
14%
 14%  [4]
no
78%
 78%  [22]
Total Votes: 28
Page 1 of 3 123>
pld118
There are so many threads on this forum about people's L322 suffering rear arch corrosion, I thought it might be interesting to find out via a poll, as to how many/ percentage of members cars are afflicted.
The results of this thread could be used by people to put a case to LR for arguing against any suggestions that it is not a design fault in the event of dealership and/ or LR warranty declining to rectify any individual cases either via warranty or good will on cars under 3 years old (paint surface warranty); under 6 years old (corrosion warranty); or over 6 years old but bought as approved used LR.
Please only take part in this thread if you are prepared to vote and answer the following six A, B, C, D, E & F questions because any posts on this thread that argue against the merits of such a thread could later undermine someone attempting to use the thread content to justify their claim to LR/ a LR dealership.
A. Corrosion found on rear wheel arches? (simply answer "A. Yes" or "B. No ")
B. Age of L322 (for example "B. 2010").
C. Failing paintwork/ corrosion to both rear arches, rear near side or rear off side (simply answer "C. Both", "C. RNS" or "C. ROS")
D. Rear mudflaps fitted before onset of corrosion? (simply answer "D. Yes" or "D. No" or "D. Don't know").
E. Rubber arch strips fitted before onset of corrosion? (simply answer "E. Yes", "E. No" or "F. Don't know").
F. Successful claim made and repairs carried out? (simply answer "F. Declined" or "F. Approved via Pwarranty", "F. Approved via Cwarranty", "F. Approved via Lr goodwill" or "F. Approved via Dealership goodwill").
Perhaps Stan or another moderator could please help with poll buttons as I'm unable to get them working?
Thanks.
Post #259630 16th May 2014 5:18am
pld118
A. Yes
B. 2007
C. Both
D. No
E. No
Post #259631 16th May 2014 5:24am
Yes
2008my
Both
Dont know
No
Probably delaler good will though they did test paint thickness There is nothing that can't be fixed with a hammer😜😜
Post #259637 16th May 2014 7:38am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
A. Yes it's old
B. 2002
C. Both
D. Yes
E. No
F. No, too old
Post #259640 16th May 2014 8:01am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
A Yes
B 2005
C Both
D Don't know but does have LR mudflaps (on when purchased)
E No
F Not attempted as too old for LR warranty There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #259666 16th May 2014 10:29am
millerj90
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
A. Yes.
B. 2008.
C. Both.
D. Yes.
E. Don't know.
F. Declined.
Post #259667 16th May 2014 10:51am
A No
B 2004
C yes
D Yes
E Yes
F -
Post #259668 16th May 2014 10:55am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
A. Yes
B. 2007
C. Both
D. Yes
E. Dont Know
F. Didn't claim as not noticiable at expiry of 6 year corrosion warranty, now a bit of a mess...
Worst thing about is that my Mrs has a 2007 BMW 320d and the build quality is better than the FFRR, doesnt have a single speck of rust or any paint issues Whistle 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #259687 16th May 2014 12:29pm
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
A.No
B.2004
C.No
D. No
E.Yes
Post #259723 16th May 2014 3:02pm
A Yes and Right Rear Quarter Panel and corner between sill and wheelarch inside door opening
B '02
C Both
D Don't know (think fitted at factory)
E No
F Too old, will do myself! .
Post #259733 16th May 2014 3:39pm
Prop
A. Yes
B. 2007
C. Both
D. Yes
E. No
F. Paid for repair myself
Post #259734 16th May 2014 3:48pm
birchyman71
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
A. yes
B. 2003
C. Both and on panel inside door close
D. no
E. no
F. to old, will do it myself
Post #259803 16th May 2014 9:10pm
pld118
Interim update:
So far, early days for the thread granted, no cars newer than 2008 afflicted (can't be an accurate representation) and not one example of rusting rear arches being covered by the LR paintwork and/ or corrosion warranty.
Keep posting Thumbs Up
Post #259806 16th May 2014 9:40pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
A no
B 2011
C no
D yes
E yes arches partly covered with rubber
F no
Post #259810 16th May 2014 9:51pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
A. Yes
B. 2006
C. Both
D. Don't Know (were fitted when I bought the car)
E. No
F. Too old to be covered under warranty, corrosion not actually too bad, will get it done at the local body shop 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #259817 16th May 2014 10:16pm
Page 1 of 3 123>
