Home > Technical (L322) > FF, L322 interior seat belt trim on centre pillars
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Hi everyone,
Need some help on the interior trim of my 2004 FF Vogue.
The soft trim on the inside of both seat belt pillars keeps coming away from the pillars. All that seems to be holding the trim in place is the seals that run around the side of the pillars? Are there any clips that may be damaged. Any advice would be great.
Thanks,
Mark.
Post #259470 15th May 2014 4:34am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Yep they are held on with some push in trim clips that bend out of line very easily I had to remove the seat to get mine to fit in place and clip in properly
Post #259488 15th May 2014 8:42am
There are 4 clips 2 half way down and 2 near the bottom but as said above they bend and fall out easily!
Post #259621 16th May 2014 1:01am
anorakmark
Thanks guys, I guess if these clips are broken then there is no way of securing the panels? or are there replacement clips available.
Post #260042 18th May 2014 11:39am
There will be replacement clips. Remove panel to see which ones they are then either pop to Halfords or ask Dan at Duckworths (send a picture to ensure you get the right ones back!)
RAVE shows how to remove, the whole trim panel top to bottom has to come off IIRC, it is in two parts that interlock. .
Post #260051 18th May 2014 12:31pm
