Home > Maintenance & Mods (L322) > Battery issue - MY11 - dealer can't figure out what it is |
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 503 |
Hi all,
14th May 2014 3:32pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Is there a battery software update for your car? .
14th May 2014 7:51pm |
Thanks both. No tracker, and because its the first time this has happened doubt they will replace the battery under warranty. In any case battery itself is not covered by LR extended warranty.
14th May 2014 9:53pm |
mmiata Member Since: 12 Jul 2013 Location: Budapest Posts: 104 |
Hi, I had the very same problem with my 12 tdv8. After a few months of use I left the vehicle in a marina for 7 days and when returning, same complete drain was observed what you described. Jump started and took to LR dealer. They identified a completely drained and short circuited battery. After a short argument they agreed the replace the battery with original LR AGM battery made by Exige. Since then - for the last 11 months - issue has not repeated. Have left the vehicle for a week since and started without hesitation. Although I got a good charger and recharge, condition the battery regularly.
15th May 2014 3:09am |
quick update as I got the car back today...
16th May 2014 8:42am |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
Also had the adhesive fail on that foam piece that closes off the underwing/door jamb hole. Twice. Seems to be absorbent so was soaking wet. |
16th May 2014 8:52am |
^ totally agree - I could have washed the car with that much water... can't say I should be surprised though... MY11 Vogue 4.4 TDV8 - "African Queen" |
16th May 2014 8:54am |
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 739 |
Shaltz do you have the AGM battery fitted to you vehicle ? early 2011's including mine were recalled for a battery swap and a software update. 2021 P400 Silicon Silver AB
16th May 2014 9:09am |
The dealer said it does and I have an invoice from March 2011 saying the battery was replaced with AGM (car was with previous owner at the time)..
16th May 2014 9:10am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Was it left at an airport??
16th May 2014 11:31am |
interesting - I never knew that about airports...
16th May 2014 1:37pm |
Know you're out of warranty on the battery Shalz but thought I'd add this:
17th May 2014 5:43am |
