Home > Maintenance & Mods (L322) > Trolley jack or Air jack?
J90
France 2006 Range Rover Vogue Td6 Java Black
I want to take the wheels off my RR for some general maintenance. I hate using a bottle jack so I'm thinking of buying a trolley jack or air jack to lift the car before placing axle stands underneath it. Any thoughts on which would be best? I'm thinking the air jack because you can just slide in underneath to suit the placement of the axle stands.
All opinions welcome. Ta. Travelling around in circles again.
Post #259096 12th May 2014 9:31pm
tsadpt
An air jack won't work on twin exhausts unless you plug one of the exhausts....
Post #259304 13th May 2014 10:32pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
3 tonne trolley jack Thumbs Up Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #259307 13th May 2014 10:38pm
ebajema
Trolley jack !! MY 2010 5.0 SC Galway green and sand interior!!
Post #259312 13th May 2014 10:59pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If you mean the air jacks used for off roading then by time you've set up the air jack and pumped it up high enough to get a wheel off the ground you could have lifted it on a trolley jack and had the wheel off. OK for an emergency on soft ground but too cumbersome and slow for working on a vehicle (I tried mine at the weekend). If you mean professional air jacks with a proper compressor then they are pretty good but expensive and need a compressor.
Post #259380 14th May 2014 12:06pm
You don't want to be under it, setting axle stands with an air jack, if it burst, or more likely slips out you'll have a Range Rover on your head....
Get a decent trolley jack... Pete
Post #259382 14th May 2014 12:37pm
Discotigger
Trolley jack every time.
I recently got a good 3 tonne high lift trolley jack from machine mart for under £60. Works an absolute treat!! Thumbs Up
Bargain Thumbs Up Thumbs Up
Post #259400 14th May 2014 5:35pm
J90
Well trolley jack it is then. Thanks for the advice everyone Very Happy Travelling around in circles again.
Post #259414 14th May 2014 7:30pm
Also got the clarke 3 tonne strong arm high lift trolley, works really Well and have just done the wheels on the disco this eve in about 30 mins, including climbing through the garage obstacle course to the back where the wheels were stored! There is nothing that can't be fixed with a hammer😜😜
Post #259452 14th May 2014 10:24pm
Discotigger
+1 Northernmonkeyjones.
Yep, Clarke strong lift that's the one I've got. Great piece of kit Thumbs Up Thumbs Up
Post #259456 14th May 2014 10:32pm
