Home > Technical (L322) > IID Tool for 2011MY |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35384 |
http://www.gap-diagnostic.com/products/iidtool.html
11th May 2014 8:45pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Thanks but I need laymans terms and it elaborated , it just says things like DSM driver seat, IPMB camera..
11th May 2014 8:56pm |
just looked at your functions and theres no LCM module listed for your year and thats where the drl is configured...i would think that you cant lolo...
11th May 2014 9:12pm |
Thanks for that I'll check it out.. |
11th May 2014 10:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Lolo, if you mean your LED sidelights then NO you cannot turn them on as DRL's using the IID... You can however turn ON canadian type DRL (which means your inner full beam halogens will run at 40% of their brightness as a DRL |
11th May 2014 10:20pm |
Hi Lolo,
12th May 2014 3:43pm |
Thank you for that explanation. I had a feeling the drl wasn't an option but somewhere on the forum somebody mentioned the faultmate could enable it. The Bluetooth version is definitely more desirable but bit pricier. I'll be investing in one soon though.
12th May 2014 4:44pm |
you could always convert the fogs to drls...... ... - .- -.
12th May 2014 6:23pm |
If you are going to be modifying the wiring to make lights come on as DRLs, you can do the side LEDs as well...
14th May 2014 7:59am |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
That was me then
15th May 2014 11:30am |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 137 |
just updated by IId tool BT version for 2011 MY - checking that adaptive lights where identified as being there ( which they were )
9th Mar 2015 1:22pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I've turned on my DRL the halo lights, with no lights on at the rear. When I turn on my lights on they do turn when I turn the steering wheel. And the cornering lights come on too. |
9th Mar 2015 11:05pm |
