Home > Technical (L322) > brake pad warning light on |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7949 |
Depends how much braking you do
11th May 2014 7:20am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
If its the rears gone and you have a rear calliper issue then it could be just a few miles! I have seen the rears go from good pads to discs ruined in under a hundred miles!!!
11th May 2014 8:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
might be worth replacing the discs when you do the pads... ... - .- -.
11th May 2014 8:45am |
Craig is right, if the calipers are having the notorious stuck caliper issue your pads are gone in no time. Although you would notice this during driving I expect and check the wheels after a shortish drive from cold and if they or one are/is piping hot, you know the caliper is a problem.
11th May 2014 8:52am |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Cheers guys
11th May 2014 9:02am |
11th May 2014 9:03am |
