Home > Technical (L322) > Tow Bar Question
Discocuzzy
Tow Bar Question
Chaps, i need a towbar that has a US 2" reciever fiting so i can tow my offroad trailer with a nato hitch, anyone know of part numbers or in fact if one is available?
Ta
Steve
Post #25824 18th Aug 2010 5:44pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
The FFRR armature takes a square receiver type drop plate tow hitch - this is bolted to a backing plate on the "hitch" and can be removed to replace it wih anything else that will fit into the same bolts positions. I converted mine to take a Freelander1 Bike rack and I can still use it as a tow hitch as well as the bike rack is mounted on a plate between the backing and drop plate hook. This is what it looks like
Part Numbers are from my 6 years old FFRR Accessories Brochure so may have changed in the intervening time:
Tow Bar Armature - Pt No VUB00740
Drop Plate Tow Bar - Pt No VUB00720
The detachable tow hook VUB00730 also fits into the receiver and Combination Towball Jaw Unit will also fit onto the drop plate instead of an ordinary hook.
I can scan the pages from my brochure if you want them
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25826 18th Aug 2010 5:59pm
is this what you need..
http://cgi.ebay.co.uk/LAND-RANGE-ROVER-DEF...arParts_SM ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #25829 18th Aug 2010 6:41pm
Tim in Scotland
At least it's about 1/10th of the price of the one I posted! 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25832 18th Aug 2010 6:51pm
its cheaper than the OE one also on ebay..[£250] ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #25835 18th Aug 2010 7:06pm
Discocuzzy
I dont need the drop plate as i have a reciever that the nato bolts to which is 2", it looks like i will just need the main assembly Thumbs Up
Post #25840 18th Aug 2010 7:25pm
nbunney
Then you will need 1 of these then:
http://cgi.ebay.co.uk/Westfalia-Range-Rove...arParts_SM
Great guys to deal with. Thumbs Up
Post #25854 18th Aug 2010 10:29pm
Discocuzzy
mmm not sure...thats just the tow hook isnt it?...i need all the metal work that mounts to the chassis with the square connection ready for me to mount my reciever/hitch.
If you look at the pic of the defender below you can see the green hitch attached to the reciever via 4 bolts that is in turn located into into a 2" reciever mounted on the cross member of the 110.
I want to be able to have the ability, using the same mounting solution, to mount the reciever to both the 110 and the rangie....does that make sense?
If i could find a pic, i recon the part number Tim quoted for the armature is the right part i need Thumbs Up
Post #25855 18th Aug 2010 11:37pm
Tim in Scotland
It looks like what you need is the armature, basically it's a subframe that has the square receiver built into it and bolts on under the car - it was LRs attempt to make one system for all markets and has interchangeable fittings that go into the square receiver. I will scan the picture of it in the morning and also take a photo of what is on my car 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #25856 19th Aug 2010 12:06am
Tim in Scotland
The armature is on the left of the picture and gets bolted onto the chassis under the car, the only problem you might have is that it is mounted very low compared to the height of the Defender's
Here it is fitted to my FFRR, the car is at access height and the armature is well recessed under the car, just in front of the rear exhaust box
Post #25869 19th Aug 2010 9:27am
D.C. i have the complete RR towbar that goes into the 2'' hole that i'm willing to flog, is that what you need... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #25873 19th Aug 2010 9:56am
Discocuzzy
Oooh..yes it is scarey, thanks Tim for the pics Thumbs Up
The height should be ok as i have swan necked the sankey (dropped 100mm and extended by 600mm)
How much do you want for it scarey?
Post #25895 19th Aug 2010 2:15pm
pm'd you D.C. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #25897 19th Aug 2010 4:14pm
