Home > Maintenance & Mods (L322) > Wheel Hub Corrosion
Bobster67
Scotland 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Wheel Hub Corrosion
Hi all, recently collected my second Range Rover Vogue, went for a 2011 Vogue in Stornoway Grey (colour I always wanted) used to have a black 2007 Vogue.
Am delighted with the car but have a couple of questions, I hope you can help me out.
Firstly, I notice that there is what looks like some corrosion on the rear wheel hub. This is the bit that the actual wheel is bolted onto, is grey in colour but is showing some signs of discolouration and indeed looks like rust coming through.
Am interested to know if this is a common problem, if it is likely to be covered under warranty and if not how best can I fix it? Don't mind a bit of DIY if needed.
Next question, the rear of my car seems to sit verily slightly lower than the front, again, is this common, am i just being picky?
Thanks in anticipation of any responses.
BTW, good to be back in a Range Rover, had an X5 in between and whilst it was an excellent drive it just doesn't have the same presence.
Cheers
Post #257719 5th May 2014 8:55am
Rear hub corrosion is a common gripe.
Some of the rear discs seem to be worse than others - the OE are awful, but I think Lockheed ones seem to stay shiny for longer.
Post #257724 5th May 2014 9:11am
I agree with alistair, however i doubt you will manage to get them to swap it over as it is part of the disc, and these arent covered by any warranty, corrosion or mechanical as they are consumable parts like pads. There is nothing that can't be fixed with a hammer😜😜
Post #257731 5th May 2014 9:44am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
When they come new they are primed. I always mask up the disc friction area and give mine a coat of heat proof paint. I also do round the edge and vents. Generally lasts the life of the disc which is not very long! 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2011 Discovery 4 3.0 HSE
2015 Discovery 4 HSE Lux
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #257754 5th May 2014 2:18pm
