Home > General > Thoughts on potential purchase
SMIA
Might pull the trigger on this.. Going to have a closer lookand take up a quiet road to check high/low range etc but anything I should be looking for on this model? All advice appreciated thanks
http://www.autotrader.co.uk/classified/advert/201404143322234
Post #257538 4th May 2014 2:22am
mjdronfield
Has a non standard TV screen setup in the dash, so make sure everything hifi and TV and sat nav etc all work to your satisfaction. Computer functions may not work either.
Prob been swapped due to water leak in the boot damaging the original electronics which can be costly to replace.
Could also have been swapped as a previous owner just liked the aftermarket unit though.
Watch the condition of the alloys as those wheels are not standard and could be overfinch tiger copies. Make sure they have not been cracked or welded up, as the car is best part of 3 tons loaded up and the wheels need to be strong enough when you whack into a pot hole.
Land rover wheels have a load rating of more than 900kg stamped on the rear of the alloy.
There is a buyers guide in the wiki section for the other stuff, wiki top right of the web page.....
Welcome to the forum !
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #257540 4th May 2014 4:55am
pld118
Parcel shelf looks stained (water damage)?
Alloys are kerbed.
Does the car seem like its trying very hard to look expensive?
Post #257543 4th May 2014 7:18am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
It also has a 'dummy' facelift front grill.
Post #257545 4th May 2014 7:39am
pld118
Be interesting to find out if it does look in as good condition as the ad text suggests... Or whether it's mutton. Hopefully, it will meet your expectations though SM Thumbs Up
Post #257546 4th May 2014 7:48am
kiter
How many miles you going to do? I'd try a similar age 4.4 V8 first and potentially save myself a pile of cash. When I went to get mine I tried both, and V8 came out way ahead, but I only do about 5k a year. Mine had 143k on the clock and I paid just over £5k for it this time last year. Can get just over 20mpg on a long run sticking to the limit - drops down to 14mpg with the caravan on the back. Sound of the V8 is just ace. make sure you have a bit put aside for the envitable repairs that it will need. I reckon mine has cost me about £800 in repairs this last year and that has been doing most of it myself (radiator, track rod ends, battery, rocker cover gasket, all new fluids and filters and just about to do the fuel pump and FSR).
Post #257555 4th May 2014 8:35am
Dont be swayed by cosmetic aftermarket stuff someone else has done.
Try and buy a nice honest standard car and the monkey around yourself! The aftermarket head unit, overfinch copy (probably) wheels, non standard towbar, aparently stained and broken rear shelf and replica supercharged grille would put me off even looking at it! These things arent too pricey to get hold of and it looks like they have been added to create a "stunning example". There is nothing that can't be fixed with a hammer😜😜
Post #257580 4th May 2014 10:14am
SMIA
Thanks fellas
Had already penciled in the removalof all the chrome and aftermarket rubbish, I've been past when the dealer was closed and from the outside it is in decent enough condition but the water mark is a concern. I think ill go back to the drawing board and find an unmolested example in hindsight I see no point in spending money returning it to its previous condition.
I saw the head unit when i looked through the window and thought it looked a bit "weird"..
In answer to kiter I'd say no more than 8000 miles a year. Girlfriend had a Fiat 500 which we tend to share as well so will mainly be dual carriageway trips to Newcastle or the odd 2 mile bad weather drive to work. I'llhave a search for V8 petrol info as I'd totally overlooked it.
Post #257606 4th May 2014 2:56pm
SMIA
A quick search of the area has revealed this but I'llhave to read up on the V8 before I enquire further. Might have to travel in the end as there's not much up here apart from blinged up examples
Post #257608 4th May 2014 2:59pm
SMIA
Saw this car on Auto Trader’s Android App. Thought you might be interested. http://www.autotrader.co.uk/classified/advert/201404012986291
Post #257609 4th May 2014 3:02pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
look at mine in for sale mate no aftermarket stuff on clean I am only the second owner off the key no heat every time
Post #257642 4th May 2014 6:43pm
Seems good value if in good nick as facelift will have cost a bit. Cannot go far wrong if you can get a bit off that.
Post #257645 4th May 2014 6:56pm
