Home > In Car Electronics (L322) > Are these the plugs that i connect a Bluetooth ULF to?
Page 3 of 3 <123
Zaskar
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
I just need the same cable in the 2nd pic that you put up in the previous page but long enough to get from the boot to the centre console. Maybe 3m?
Many thanks.
Post #257012 30th Apr 2014 3:03pm
ccfj1
If that's all you need, just get some normal 2 core shielded wire then mate.
Post #257015 30th Apr 2014 3:07pm
Zaskar
Hi ccfj1,
Where would I get the connectors from? Although I could break into the wiring I would like to be able to just click and connect. Plus it looks a little more professional with connectors. I have been trying to find them all over the net and in shops but to no avail. Sad
Your advice is greatly appreciated.
Many thanks.
Post #257017 30th Apr 2014 3:16pm
ccfj1
BMW mate, parts department.
Thats why I was asking for a pic, I could give you the right part numbers then!!
Post #257018 30th Apr 2014 3:17pm
Zaskar
They are exactly the same as the ones in your pic Smile
And the pics of the mic connectors in the centre console area and roof console in the installation guides mentioned previously. I have already connected the mic up to the roof connector.
I tried to copy and paste the pics from before but it won't let me Sad.
Thank you though. I'll get to my old BMW dealer. Smile
Many thanks.
Post #257020 30th Apr 2014 3:22pm
ccfj1
1 x 3pin plug (male) 61.13.8.377.072
1 x 3pin plug (female) 61.13.6.931.929
3 x pin termination (male) 61.13.0.006.664
3 x pin termination (Female) 61.13.0.006.663
And any decent 2 core shielded wire.
You will need to solder and heat shrink the pin termination and then insert them into the correct plugs.
Job done.
Post #257021 30th Apr 2014 3:26pm
Zaskar
http://www.bimmernav.com/images/rovermic.jpg
http://www.roverupgrades.com/images/rover_install_127.jpg
These are the links to the pics with the correct connectors on mate. I gather they are standard from BMW?
Cheers.
Post #257022 30th Apr 2014 3:27pm
Zaskar
Fantastic. Many thanks mate.
Much appreciated Smile
Post #257023 30th Apr 2014 3:29pm
ccfj1
those 2 are the same type male!!. so you may need two female plugs and the correct pins.
Post #257024 30th Apr 2014 3:29pm
Page 3 of 3 <123
