Home > In Car Electronics (L322) > Are these the plugs that i connect a Bluetooth ULF to? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
There is a pic on here showing the mic connector under the centre console, but you've prob seen this page already.........
24th May 2013 4:04pm |
Have you dowloaded RAVE from the link in the Wiki section ?
24th May 2013 5:38pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
the mic plug is under the centre console very deep down, i had to take the console out on mine to find it. its under the heater ducting pipe near the passenger seat at the rear, the wires will match exactly when you find it to the roof plug. |
24th May 2013 10:35pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Thanks mate, will rip out the console ! 2003 Vogue 4.4 V8 Java Black |
25th May 2013 7:08am |
Zaskar Member Since: 17 Mar 2014 Location: Oxfordshire Posts: 18 |
Hi there, sorry to come in at the end but ccfj1 mentioned about the mic cable. Are these freely available on the market or are they bespoke? Please could someone point me in the right direction as I have all the other components except the cable.
30th Apr 2014 9:55am |
ccfj1 Member Since: 14 Feb 2013 Location: UK Posts: 32 |
The mic lead in the pic (that I posted) was bespoke. Not sure if its available form either Rover or BMW. |
30th Apr 2014 10:02am |
It should still work if you run the connections as below ;
30th Apr 2014 10:47am |
Do you still produce them at all ccfj1? Sorry to be cheeky? Or if not where I could get the connectors from?
30th Apr 2014 11:49am |
The mic lead?? it will depend on what you have mate, how will you be putting the mic inputs into the 54 pin plug? |
30th Apr 2014 11:52am |
Hi ccfj1,
30th Apr 2014 12:07pm |
Sorry, forgot to mention that I have a 04 l322 Vogue.
30th Apr 2014 12:12pm |
So the BT loom that you have has the mic input plug then?
30th Apr 2014 12:13pm |
Hi ccfj1,
30th Apr 2014 1:09pm |
OK, Can you take some pics of what you have and I'll see if I have what you need. |
30th Apr 2014 1:10pm |
