Home > Maintenance & Mods (L322) > False alarm acivations !!!!!!!!!!! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You could try setting the alarm without the interior protection and see what happens.
28th Apr 2014 9:20am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I had problems with the alarm going off at random and it was the catch under the bonnet. I fixed it by sticking a self adhesive foot on the bonnet underside. A simple test is to disconnect the switch, I can't remember if you leave it open circuit or have to short it out. HTH Geoff |
28th Apr 2014 10:21am |
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 |
^ me too. I disconnected mine and haven't had an activation since. |
28th Apr 2014 10:25am |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
Is it possible you have a radio source causing the triggers?
28th Apr 2014 10:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
bonnet switch is most likely... ... - .- -.
28th Apr 2014 11:13am |
Stretman Member Since: 06 Feb 2014 Location: Staffordshire Posts: 9 |
thank you all
28th Apr 2014 12:11pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
bonnet switch most likely had the same with mine,just disconnect for a week to try |
28th Apr 2014 2:17pm |
Hi all
1st May 2014 9:52am |
I used a self adhesive foot I had hanging around, worked a treat. I also "excercised" the switch and gave it a spray of switch cleaner. Geoff |
1st May 2014 9:56am |
re the lights Ray, its possible you have led bulbs fitted that are not canbus error free....if this is so then you could replace them with proper leds or get a diagnostic tool to switch off the error checks. ... - .- -.
1st May 2014 10:01am |
