Home > Maintenance & Mods (L322) > Loose windscreen wiper
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Lo Peeps
Am having problems with the passenger side windscreen wiper.
I will be the first to admit I am not good when it comes to things like this going wrong but each time it has happened it becomes loose again and yesterday while out it came loose again, tightened it up again and by the time I got home it was flapping about after only a short journey.
When tightening it up the one thing that really concerns me is over tightening it but what ever I am doing its not fixing the problem, a friend suggested using one of these nylon nuts on it but wasn’t keen on that idea as not sure if you should use a nut like that.
Every thing else on the wipers seems to be ok.
Sorry if my description isn’t that good but any advice would be much appreciated.
Cheers
Dave
Post #256297 26th Apr 2014 10:13am
is it the wiper assembly which is bolted onto the spindle or the wiper blade part which comes lose Dave.. ... - .- -.
Post #256299 26th Apr 2014 10:51am
Muttley
Hi Stan .its the wiper arm blade nut that keeps coming loose.
Post #256300 26th Apr 2014 10:57am
supershuttle
Loctite might help. Geoff
Post #256302 26th Apr 2014 11:02am
this is from the WM and i would check to make sure you have all the components,
and here's a description of said components, hope this helps some...
Post #256305 26th Apr 2014 11:08am
Muttley
Thanks Stan Thumbs Up will have to have another look , am hoping my mechanic can have a look at it some time today.
Post #256309 26th Apr 2014 11:15am
Muttley
Have printed the information you have posted Stan , thanks you for that Thumbs Up as I am seeing my mechanic this afternoon and hopefully with that diagram he might be able to work out what is going wrong and get it fixed.
Nothing worse than having dodgy wipers in this weather Sad
Probably should of added the fact that the couple of times I have tightened it up it didn't stay where I had tightened it , it dropped down , nearly below the screen so probably done more harm by trying to fix it myself Embarassed
Dave
Post #256445 27th Apr 2014 9:11am
the trick is to screw clockwise and no anti-clockwise Dave Laughing .... Wink ... - .- -.
Post #256481 27th Apr 2014 1:22pm
Muttley
hmmmm Razz
I should of just left it alone really and got it to my mechanic , was a struggle just to try and tighten it up and after reading the information you have posted , if that is a locking nut I think it might be knackered but hopefully my mechanic can sort it out and maybe see if he can get my bosch battery to fit properly Laughing
Post #256486 27th Apr 2014 1:35pm
Gotta take mine off soon as a stone has broken the deflector and connector where the blade attaches.
Not having a good ff weekend! There is nothing that can't be fixed with a hammer😜😜
Post #256562 27th Apr 2014 6:21pm
Muttley
Thanks to my mechanic it is all fixed now and he used some lock tight on it .
Having the diagram from Stan really helped Thumbs Up
There are signs of wear on parts 6 and 7 and both plastic caps on each wiper need replacing but no big deal , am just chuffed that the wipers are all ok now Thumbs Up Thumbs Up
might go the whole hog are replace the wiper arms as at some point I think the bonnet must of been in access mode as there is a crease in the drivers wiper arm and looks like the only way it could of happened is the bonnet crushing it.
Post #256566 27th Apr 2014 6:31pm
Mine has a nick in the plastic cover where it was badly fitted in the wrong position after a new screen was put in and caught
On the bonnet! There is nothing that can't be fixed with a hammer😜😜
Post #256569 27th Apr 2014 6:36pm
