Home > Technical (L322) > Automatic gear box oil level
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Wise words by RRPhil again. I can't believe any one would seriously get under a car in D with someone else holding the brake pedal. Rolling with laughter The difference between theory and reality is that in theory it will work.
Post #255346 20th Apr 2014 9:27pm
On a two poster ramp Whistle Whistle Whistle No danger there Thumbs Up
Post #255347 20th Apr 2014 9:35pm
RRPhil
From RAVE :
From ZF (for the 5HP24) :
(With reference to the non-vehicle specific instructions from ZF above, the V8 Range Rover won’t allow you to select higher gears manually when stationary in high range, though the TD6 will allow 2nd gear to be selected)
Phil
Post #255350 20th Apr 2014 10:01pm
Post #255352 20th Apr 2014 10:06pm
Av_dave
Yer on a ramp would be fine sorry I had visions of doing it on someone's drive with you under it and the wife inside. Thumbs Up The difference between theory and reality is that in theory it will work.
Post #255376 21st Apr 2014 8:07am
