Home > Technical (L322) > What's this rad for?
Wookie
United Kingdom 2006 Range Rover SE TDV8 Giverny Green
In front of drivers side wheel there is a small rad what's this for?
Post #255289 20th Apr 2014 1:35pm
Winchester101
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Not a clue I'm sure someone will come along an tell ya
What vehicle is it ? 1994 softail full stars n stripes custom harley davidson
Post #255292 20th Apr 2014 1:59pm
stu
not sure about locations of things as you have not said which car its on, but sounds like an intercooler if its small and in a wheel arch!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #255295 20th Apr 2014 2:43pm
Wookie
It's on a 2006 tdv8
Post #255303 20th Apr 2014 3:24pm
adigorn
Already stated in leak tread
but if necessary will confirm again
its auxiliary coolant radiator to help exchange heat when "flooring" Twisted Evil Tdv8
Post #255328 20th Apr 2014 7:20pm
Wookie
Thanks for the info i confidently removed the hose and drained the coolant refitted the hose and added a jublie clip problem solved.
Just as i thought my troubles are over I notice oil around the top of the steering rack!
Presumably not normal?
Post #255492 21st Apr 2014 9:43pm
