Home > Maintenance & Mods (L322) > tailgate straps
Page 4 of 6 <123456>
Laughing ... - .- -.
Post #254722 16th Apr 2014 1:07pm
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
Rolling with laughter Rolling with laughter Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #254727 16th Apr 2014 1:30pm
Mutley
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Wow how funny I was just logging on to call Dan but thought I'd check if there is any history & its on the top of the page Rolling with laughter mine has just snapped Big Cry
Going to call Dan now Bow down Mutt
FFRR Black TDV8 Vogue MY08
Post #254737 16th Apr 2014 4:14pm
supershuttle
Well I'm pleased to note that my straps are fairly rust free Rolling Eyes Geoff
Post #254747 16th Apr 2014 5:49pm
silversurfer
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Orkney Grey
stan wrote:
this thread is worth a resurrection, so check your straps.. Wink ..
Couldn't believe the amount of rust I found on both straps .
Now sorted.
Many thanks to the forum. Thumbs Up
Post #254996 18th Apr 2014 2:53pm
surprising isnt it...it must be a water trap.. ... - .- -.
Post #255001 18th Apr 2014 4:13pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Did mine today, they were pretty rusty although not on the point of failure.
Post #255621 22nd Apr 2014 8:57pm
i bet if you had 26 stone on your tailgate they would.... Laughing ... - .- -.
Post #255629 22nd Apr 2014 9:48pm
Robgosty
Read this, checked mine, knackered Sad they were so rusty torx bolts rounded off, had to cut cable with angle grinder, give the ends a smack with hammer to get em moving then cut the strap off as close as possible to bolt to turn em out as the ends were rusted into one piece, all four mountings the same and on a 2007 car as well, new uns fitted and dunked in grease pot before fitting, bit messy but they aint gonna rust again Thumbs Up
Post #272562 24th Jul 2014 8:58am
rar110
One of mine broke in the last couple of days. is Dan at Duckworths still the man? ______________________________
Post #364090 27th Dec 2015 1:52pm
He is a man, and will be able to sort them Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #364139 27th Dec 2015 8:18pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
After reading this post I decided to check my tailgate straps, and surprise surprise they were indeed rusty, not as bad as some examples on here but well on the way Big Cry (see pic below).
Dan at Duckworths kindly put 2 in the post and they were duly fitted today.
Before fitting I coated the metal parts with Zinc paint and topcoated in Black, also replaced the hex head bolts with stainless ones and smeared some copper grease on the bolt threads. I also coated the metal ends with silicone grease and forced some of it down the cable covering.
Will check for rust in 7 years Whistle
Peter
Post #365544 5th Jan 2016 11:50pm
rar110
Good ideas there Pete. I will do the same when I receive replacements. How long ago did you order yours? I sent an email an nearly 2 wks ago but no reply yet. Maybe they are still closed for xmas-NY. ______________________________
Post #365568 6th Jan 2016 12:47am
Ian c2
United States 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I was thinking of doing the 2010 upgrade to my car .
Is the same rust problem evident on that setup as well ?
Post #365574 6th Jan 2016 2:16am
p38arover
Australia
So nothing has changed from P38A days. I had a couple rust away on mine. Best I check the L322.
After the last failure which was in the middle of the loop (I assume water has run down in the the outer tube and collected at the loop), I went to my local stainless steel balustrade guy (next door the coffee roaster I frequent) and got some cable off him (for the cost of a cup of coffee Smile ). I cut off the crimped ends at the pivots, and silver-soldered the stainless steel cable into the ends. I now have a spare P38A cable I bet it won't fit the L322. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #365577 6th Jan 2016 3:10am
