![]() | Home > In Car Electronics (L322) > Front Cigar Lighter |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
This is going to sound stupid but......was the ignition on? My front lighter socked is a switched live....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
+1 what he said.. ... - .- -.
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Yes, the ignition was on, the centre socket is also only live when the ignition is switched on.
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
The cigar lighter sockets are also switched through relays in the rear fusebox cubby. Could be that the relay for the front cigar lighter socket has gone.
Thanks for the advice. There is only 1 relay in the rear cubby, which feeds both the front and centre sockets when the ignition is on. As this relay is identical to the rear screen heater relay next to it, I swapped them over, the rear screen heater still works, with the ignition 'on', the centre socket works but the front one still doesn't |
re your .bmp, try converting it to a jpeg file. ... - .- -.
Norway Member Since: 09 Dec 2012 Location: Høvik Posts: 123 ![]() ![]() ![]() |
how did this end? -03V td6
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I'm not too sure what type of lighter socket is fitted to the ffrr, but, the ones that they fit in the Landcruiser have a fuseable link in the socket, as well as the fuse in the box. And nine times out of ten if you overloaded the socket the link would blow before the fuse |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 ![]() ![]() ![]() |
How did the cigar lighter problem end , did you resolve it.
