![]() | Home > In Car Electronics (L322) > Venturecam cradle comes down... |
Playsatan Member Since: 10 Feb 2013 Location: Glasgow Posts: 46 ![]() ![]() |
I have this issue also. I'm going to attempt to fix it with some velcro sticky pads to help hold it in place. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3894 ![]() ![]() ![]() |
I also suffer from this, I currently workaround by stuffing the microfibre cloth I use to clean the screen underneath the cradle so I would be interested if anyone has a proper fix or even a better workaround. Geoff |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Tear off a bit of beer mat and stuff it up the side to keep cradle shut. Cheap fix! Previous cars:
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 167 ![]() ![]() ![]() |
Hi Guys,
Mine is now fixed with velcro, also tried the beermat - both work. However if it can be fixed properly that would be better so I'll be watching for any updates. Geoff |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Hi Geoff,
Hi
3. remove any foot mats and then remove the panel that covers the lower side of the A-post: best started with a lever (plastic) in the top at the door rubber (next 3 photo) 4. Then undo the resting two torx screws; one at the under outer side and one at the side (behind the side panel) 5. Now be carefull: open the glovebox and then you can see the attachments on that side of the cradle: these are slid-in fixings (one at the top of the cradle pointing at it with a screwdriver on the next photo, and one at the bottom, not visible) so the only way to undo them, is to gently pull the panel towrds the floor/seat of the car. 5. Now the cradle comes losse and you can unplug the electrical plugs (2); the big one has a clip that has to be pushed in to come loose. 6. Now the cradle can be pulled out completely. Look at the backside and you'll see 6 or 7 screws. Undo them all and seperate the parts (housing and cradle) 7. After that you'll see 2 srews at the back of the cradle; also undo these en pull out the mechanism 8. Now look at the mechanism and you can see that there is only one side that must keep the cradle closed and the thing is made of plastic and it only has about twice a millimeter hook to hold that thing. No wonder that these hooks get rounded by using them! 9. I fixed this by sharpening these hooks again by filing them; it keeps the door really shut ![]() 10. Putting alltogheter again is straightforward execept for the thing that I took off the panel that holds the window airbag because it is impossible to put the wood back without damaging this part (I allready did a little damege to it by dismantling the wood in the first place: so best t remove this thing before touwing anything else). All it took, with taking pictures etc was about 1� hour. Now have a ventureucam that is always loaded and ready to use! ![]() |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Good write up - thanks (mine is OK at the moment, but it's only a matter of time.... |
Very good work sir |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Nice work Rangie4fun, this might get wiki'd too |
Yes, it was a Rangie day! Fixed the cradle, blocked the EGR (cleaned it out and re-installed in the closed position and blocking the exhaust to EGR with a small metal sheet, and blocking the vacuumpipe) and finally did some leather cleaning and palying with the IID tool (chirp on closing and clearing all the stored faults).
