Home > Technical (L322) > 3,6tdv8 DPF ful Warning, any DIY tips or help? |
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 |
Just had this on my 4.4 TDV8 caused by my "reduced performance" being driven for a couple of days and was told by a dealer the DPF regeneration procedure was 55mph or more for a minimum of 25 mins i.e. A good blast along a motorway!
11th Apr 2014 8:27pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Needs a good blast for at least 20-30 mins at motorway speeds to get it up to temp and burn off the deposits!
11th Apr 2014 8:41pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Hi,
11th Apr 2014 8:56pm |
To ad on this: you don't need to drive at higher speeds (altough it is the easyst way) because the revs is producing the extra needed heat. This means that you can drive easliy trough town for 20 mins or so but you MUST keep revs over 2200 RPM, this doing by using the manual shift option |
12th Apr 2014 6:15am |
Seabass Member Since: 05 Feb 2014 Location: Värmland Posts: 88 |
Thanks gents, love this forum 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
12th Apr 2014 7:33am |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Another reason to go for a good V8 petrol, especially if you are doing a lot of short distances. |
12th Apr 2014 7:45am |
Took it for a 15min drive over 2200rpm and problem solved 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
12th Apr 2014 10:36am |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Power of the forum again GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
12th Apr 2014 10:50am |
