Home > Technical (L322) > Help with head gasket/coolant loss please! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
do you have the correct pressure cap on?....do a search re the type you need.. ... - .- -.
8th Apr 2014 10:25am |
vogue12345 Member Since: 25 Jun 2013 Location: UK Posts: 18 |
Hi Stan
8th Apr 2014 11:03am |
i'd double check to see if yours is a 200 psi cap before you start looking elsewhere,
8th Apr 2014 11:25am |
Thanks Stan - will head out shortly to check that and let you know.
8th Apr 2014 12:00pm |
i tend to think that the radiator could have been the main cause of the water leak..creamy slim in the oil should show if the head gasket has gone. ... - .- -.
8th Apr 2014 12:36pm |
Hi Stan
8th Apr 2014 3:05pm |
although there is a member that has had a 140 cap on his 4.4 petrol for a while with no problems, consensus is that the proper 200 should be fitted.. ... - .- -.
8th Apr 2014 3:30pm |
Ok thanks Stan - will get on the case! |
8th Apr 2014 4:55pm |
Winchester101 Member Since: 13 Jun 2013 Location: Essex Posts: 236 |
You don't always get slime in the water Stan from the waterways to the combustion chamber I just had head gasket done you need color Change thing ( will look what it's called when I get home ) pressure is a good sign of head gasket gone though 1994 softail full stars n stripes custom harley davidson |
8th Apr 2014 6:07pm |
thanks for the info.. ... - .- -.
8th Apr 2014 6:08pm |
8th Apr 2014 7:40pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
These coolant systems are a.pig when they start leaking. As you fix one week point another one appears. Just a downside to age and a pressurised system. If you have stopped loosing coolant run the car for a while and feel the top hose. If its got no flex/give in it you could have pressure HGF issues. The sniff tests are good but the fluid can go out of date and give false readings. As I was aware if hou left it overnight and it had pressure in the morning this was a sign of NO hgf as the water wouldnt be leeking into the cylinder dropping the pressure. No his could also indicate an extrernal leak not only HGF issues. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
9th Apr 2014 7:07am |
Thanks for the info Rob - have been driving it recently and watching the temp gage. So far it's ok so will just keep monitoring it.
16th Apr 2014 4:35pm |
hammiegt Member Since: 28 Sep 2013 Location: wrexham Posts: 125 |
Hi, I have a 2003 4.4 v8 which had ongoing coolent loss for about 4 months, no obvious leak, had system pressure tested, all ok I was worried about headgasket, but in the end, the smallest of leaks showed itself on the back of the rad, new rad and thermostat, and its been all good since, and this really was tiny, at full temp, after some fast driving, it was the tinyest puff of steam coming out of the back of the rad, almost undectectable to the eye, but it was enough for low coolent about every 400 miles 2003 ffrr v8 vogue |
20th Apr 2014 10:00pm |
