Home > Maintenance & Mods (L322) > A very eventful night
A11EXU
Location: Bishopton (Near the Big Muddy Field at Langbank) , SCOTLAND
Scotland 2004 Range Rover Vogue Td6 Adriatic Blue
Whistle New Thermostat fitted - 90 minutes Cool
New Bosch Fuel filter - 5 minutes
New Bosch Air Filter - 20 minutes
Got rid of the Foam Engine Breather Filter swapped for the modified Venturi type - 10 minutes when Air Filter being done
Cleaned out the MAP sensor - my imagination or did i get more Turbo boost on way home - 10 minutes
Temp Gauge at 12 o'clock first time since owning
23 MPG on way home
Just need to change my Footer at bottom of page
All in all a very satisfying nights work
I am a FFRR annihilator !!! Mr. Green
Just need to wash it now Embarassed '54 Adriatic Blue Vogue
Post #252553 3rd Apr 2014 10:04pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Looking good bud. I've got an ever growing pile of bits waiting to go on too. Part of that will be an oil and filter change and and an uprated air filter. Where about was the sensor you cleaned?
Post #252560 3rd Apr 2014 10:12pm
A11EXU
At the very back of engine
Changed it on my last 5 series BMW and it made a big difference
Held on with a 10mm bolt
Took it out and it was blocked
A little brake cleaner and a fully functioning MAP sensor '54 Adriatic Blue Vogue
Post #252565 3rd Apr 2014 10:23pm
paul271
Cheers mate I'll add that to list!!! Thumbs Up
Post #252566 3rd Apr 2014 10:26pm
Is a MAP sensor the same as a MAF sensor?
As in Mass Air Flow? Discovery 4 HSE
Post #252613 4th Apr 2014 7:47am
map = http://en.wikipedia.org/wiki/MAP_sensor
maf = http://en.wikipedia.org/wiki/Maf_sensor
Wink ... - .- -.
Post #252618 4th Apr 2014 7:53am
mjdronfield
Well done.
Goes off to read up on map sensor.......... Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #252623 4th Apr 2014 8:09am
