![]() | Home > General (L405) > Drive Selector issues again |
tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691 ![]() ![]() ![]() |
so what if the electronic switch fails in the dummy gear knob Far to many gone... |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
lets add to the flames.
Depends when the electronics fail, up or down, but then there are a million other things which could fail. Is there a history of mass failure? I do not frequent the Jaguar forums but this mechanism has been in place on the XF and L322 for a long time now.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I HATE column shifters! Rolls Royce, no. It reminds me of twenty year old Crown Victoria taxis! I haven't tried the rotary knob, but at least it's in the correct location. |
CaptainG Member Since: 16 Dec 2013 Location: Bristol Posts: 13 ![]() ![]() ![]() |
Car has been returned, lets hope this drive selector module lasts more than 3 months, all ok so far but have only had 2 trips. |
NormanP Member Since: 15 Mar 2013 Location: Oxford Posts: 136 ![]() ![]() ![]() |
Mine (one year old, 12K miles) has started to show this same fault (so far has not failed to rise eventually), only occurs after it has been standing e.g. overnight or in a car park for several hours. Booked in to dealer for warranty attention next week, but does anyone have details of what the recognised issue is - software update? On Topix I see Field Actions “Q406 - GateWay Module Software Update”; “Q363 = RFA Software Update”. Under Technical Bulletins I see “LTB00455v4 - Transmission Rotary Switch Module - DTC Diagnostics”. Under Special Service Messages I see” SSM71890 - Transmission Selector Switch Fails to Rise”
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1099 ![]() ![]() |
I am seriously considering asking if SVO would build me a car with the sport lever, at the end of the day it is just a set of electrical switches. letters not necessarily in the right order |
I'm sure they would, but having had a SSRR on loan for a day it might not be quite as simple as bodging a stick in there. The Sport lever is more confusing than the rotary knob. There is an interlock switch (not present on FFRR) to move into gear and when you want to engage park there is another, different, button. It is only a glorified paddle. Within an hour I was fed up with it and wanting the simple knob back. As the function is different I suspect the software for the gearbox is different and so are the LCD messages too..... Interested to know what response you might get from SVO but not for me.
