Home > Maintenance & Mods (L322) > Help it stopped
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Help it stopped
Hi any ideas, I've a 2005 3.0 diesel today I was driving along and it felt like a slight miss fire then run okay about 4 minutes later I pulled over for something to eat and the car was ticking over normally but then stopped and will not restart Sad
Post #252247 2nd Apr 2014 6:12pm
mjdronfield
Fuel pump would be my first guess.......... sounds like lack of fuel.
Can you hear it buzzing ?
When mine failed, the AA man took the rubber hoses off my fuel filter, and watched when I turned the ignition on - no fuel through the pipes...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #252251 2nd Apr 2014 6:24pm
What about tapping the pump.. Hard. I'm sure some folk have got it pumping again until they got a new one. I'm referring to the pump under the car. Previously..
Post #252253 2nd Apr 2014 6:36pm
mjdronfield
You have to unscrew the plastic cover before the in line pump is accessible.
Under the sill near the rear passenger door. 2 nuts hold the plastic cover on. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #252254 2nd Apr 2014 6:38pm
^ That's the one... Thumbs Up Previously..
Post #252257 2nd Apr 2014 6:47pm
srpara
taken the pipe off the filter and nothing coming out of it Sad is the cover for the external pump the one under the car or somewhere on the side of it n/s/r
Post #252258 2nd Apr 2014 6:48pm
mjdronfield
Not sure what you mean.
The in line pump is under the car near the sill under the rear passenger door. Fairly big plastic cover under it, about 12 inch by 4 or 5 inch, held on by 2 nuts if I remember right.
Take that off and the pump is up there with the fuel pipes connected to it.
Think I'm with you now....... You'll have to lie on the road and look behind the sill on the underside of the car. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #252259 2nd Apr 2014 6:53pm
mjdronfield
Top of fuel tank ;
2 is fuel pump
4 is secondary fueld pump.
4 is what you are trying to get to....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #252261 2nd Apr 2014 7:03pm
srpara
Thanks guys I found the little Censored and as suggested gave it a hard hit or two and the car runs again Very Happy
Will be onto Dan in the morning for a new pump.
Once again Thanks for your help Thumbs Up
Post #252264 2nd Apr 2014 7:14pm
mjdronfield
Result Thumbs Up
Happy to have helped.
I've got about £147 plus vat in my head, retail, if I remember right.
Nearly a year ago...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #252267 2nd Apr 2014 7:20pm
srpara
would you like to make a donation Wink Whistle
Post #252268 2nd Apr 2014 7:28pm
mjdronfield
Unfortunately, I only offer theoretical help, not actual help...... Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #252270 2nd Apr 2014 7:30pm
Good stuff.... Glad to have helped.. It's great when hitting something hard actually fixes things. Laughing Previously..
Post #252282 2nd Apr 2014 7:52pm
