![]() | Home > Maintenance & Mods (L322) > battery drained |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
yep normal...you cant run the FF like that as its got loads of ecu's to power and they run the battery down very quickly.. ... - .- -.
paul r Member Since: 27 Feb 2012 Location: Nantwich Posts: 213 ![]() |
Av_dave Member Since: 31 Dec 2012 Location: Stourbridge West Midlands Posts: 109 ![]() ![]() ![]() |
Unless using an optimate type charger that's on all the time and maintains the battery from what I was told it's always a good idea to disconnect the battery to give it a good full charge. The difference between theory and reality is that in theory it will work. |
no problem dis-connecting it, but read the 'how to' in the wiki.. ... - .- -.
Can I not just disconnect the negative terminal to charge the battery? |
Yep I would drop the pos of the battery then charge it in place. The difference between theory and reality is that in theory it will work. |
I left the trickle charger on over night then at lunchtime I connected my freshly charged jump starter and she fired up again, left the car running for 10 mins, then put back in trickle charge.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Hope it hasnt goosed the battery, they dont like going flat! There is nothing that can't be fixed with a hammer😜😜
