Home > Technical (L322) > WARNING and HELP needed
dingg1
on the tools recommended thread I rec'd an ELM327 wifi interface for fault reading looking at fuel trims etc,
anyway I got one from ebay (someone had used one with his iphone previously on my car and it worked fine)
so when I plugged it into the car I ended up with a high pitched squealing noise from the ecu area , the suspension is showing a fault (it thinks that a door is open so will not change height ) the interior lights don't come on with doors opened, the central locking doesn't work, and my iid tool no longer is recognised.
I have tried a hard reset , ie battery disconnect and leads touched together , still the same .....
oh dear!!
over to you guys for any thoughts/help
Post #251494 30th Mar 2014 8:50am
5a fuse in the glove box... Check them all though... Thumbs Up
Post #251497 30th Mar 2014 8:58am
dingg1
Bow down
Sorted - thanks very much, panic over - thought I'd destroyed some of the cars brain Shocked
Post #251504 30th Mar 2014 9:27am
Which ELM327 did you get? Or was it simply a case of accidentally shorting some pins when you plugged it in?
FWIW mine looks like this (but it doesn't have "Made in China" on the sticker, and it has a bluetooth logo before the OBD)
Post #251515 30th Mar 2014 9:55am
dingg1
Probably a chinese rip off for 13 quid on the bay Laughing
will try it on the sons bmw , later , he's away for a month or two , so any disasters and it can be fixed in good time.
which software are you using ? and did you have any problems setting it up
heres a link to the one I bought (wifi version)
http://www.ebay.co.uk/itm/290963091284?ssP...1439.l2649
Post #251520 30th Mar 2014 10:09am
