Home > Technical (L322) > TD6 gives out quite strong diesel fumes when warmed up |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
sounds like a fault to me, either a fuel leak or your injectors are goosed.
21st Jan 2009 4:01pm |
SHC Member Since: 21 Jan 2009 Location: London Posts: 5 |
Thanks for this. I've not noticed any diesel on the ground and it only smells when the engines running. I'll have a look this weekend.
21st Jan 2009 4:14pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
My dad's TD6 developed a split in a fuel line but not leaking underneath, it stank of diesel though. Discovery 4 HSE
21st Jan 2009 5:09pm |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 |
When you say diesel fumes, do you mean unburnt diesel smell or fumes from combustion?
22nd Jan 2009 8:29am |
Larry, Thanks for this. Its burnt diesel fumes and stops immediatly after turning the engine off. It happens at all temperatures, even when I haven't tried to use the fuel burner for weeks. I've also posted a thread about the fuel burner as well as it comes on (the fan runs) but doesn't heat up the car at all even at minus 2 degrees. I checked the fuse for the fuel burner and its OK (in fact the system/fan runs quite happily without the fuse in). Any light LR can throw on yours may help anyway (good luck with yours).
22nd Jan 2009 9:52am |
