Home > Technical (L322) > Parking Distance Control issue
ij.brooks
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Hi everyone, I would like some advice about my problem, 2 days ago my parking sensors stopped working, same issues as in several other posts, 3 second constant tone and light then flashes on pdc button, I ve checked all the sensors front and rear for clicking and they all work, I have also unplugged front and rear sensors from pdc unit behind fuse box but still get tone and flashing light. Does this mean that the pdc unit is faulted, or could there still be a issue with sensors or wiring and pdc unit has just logged a fault. I have checked through many previous posts but still unsure that if I get clicking from all 8 sensors that they could still be the problem, hoping its the pdc unit as it seems easy to replace.
Post #251113 28th Mar 2014 10:04am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
The 3 second tone just indicates to the driver that there is a fault somewhere n the system and the PDC ECU base shut the system off. If all 8 sensors are clicking then it would indicate that the sensors are fine and the wiring is fine. I would start with ECU and replace it. It doesn't need to be coded, it is just plug and play. You can take a look through ebay for BMW X5 ECU's and off the top of my head a new one from LR will cost around £140.
Cheers
Steve 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #251310 28th Mar 2014 11:38pm
ij.brooks
Thanks for the reply, I was hoping it was the ecu as it seems easier to replace. I will check ebay first, once I remove old one as I believe there is a part number stamped on it. Once again, thank you for your reply.
Post #251337 29th Mar 2014 8:23am
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
This may be useful >>
Paul
Post #251346 29th Mar 2014 9:32am
ij.brooks
Thanks Paul, This was one of the links I viewed, it was helpful with identifying the clicking noise you get from the sensors and how to remove the unit from behind the fuse box. Thanks again.
Post #251351 29th Mar 2014 10:34am
paulmoran2
I had the same issue and it ended up being a loose connection on the loom. I had to remove the rear bumper as the connection is sited below the offside rear fuse compartment, behind the bumper section below the fuel filler.
Paul
Post #251352 29th Mar 2014 10:53am
Rear loom most likely as above. Connectors can get loose or rusty. Thumbs Up
Post #251355 29th Mar 2014 11:32am
ij.brooks
strange but they has been working this evening, now wondering whether it is water issue but fault first started when weather was dry and since has been heavy rain and damp, or whether fault has cleared it self. Hopefully it will not come back. .
Post #251422 29th Mar 2014 6:52pm
