Home > General (L405) > Door and rear panel out of alignment
Gremlin
United Kingdom 2014 Range Rover Autobiography 5.0 V8 Santorini Black
This is on my LWB. The drivers rear door and rear panel don't match up. Door opens ok, no draughts or water leaks, and I don't want them to mess around with the rear panel. Is it worth rejecting its bad for 120k car
Post #251328 29th Mar 2014 7:24am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
In my limited opinion......It is bad, yes. But keep an open mind and ask them to put it right. If it isn't corrected ask them to do it again. If that doesn't work then reject it....
Door adjustment should be simple enough, I'm sure you will be happy once they've done it. Thumbs Up 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #251336 29th Mar 2014 8:12am
Gremlin
Yea I can see what you say. But on a 10 day old car and the suspension knocking. Quality control come to mind.
Post #251340 29th Mar 2014 8:47am
SKOT
Well the knocking suspension is clearly an issue with the new product. I'm not sure whether LR acknowledge that yet but having worked for an OEM myself a fix for future cars and a mod for the existing will be along at some point. There is always something with any new product. L322 and front diff is a case in point but it was fixed and once done, it's sorted.
I would write to the dealer, copy LR customer services. Keep copies of everything, include in your complaint what you want done about it (I can remember getting lots of complaint letters and it was actually much simpler in the very rare occasions a customer said what they wanted done to put the matter right!).
I'm sure the car will soon be sorted. The door is simple enough to fix and the suspension will have a mod at some point, you may just have to wait a bit.
But if not, you will have a good audit trail and all the grounds to reject the car. Let's hope it doesn't come to that.
Remember, it's a Land Rover and it's been built in an ex BL shed! 2006 4.2 SC
Post #251341 29th Mar 2014 9:02am
I can only presume something must be loose on the door hinges and the door has moved... Otherwise from looking at the pictures you have posted the alignment issues should have been raised long before you have spotted it... This could be a good reason to have the issue looked at more urgently sir... Neutral
Post #251350 29th Mar 2014 10:32am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Can't believe that could have left the factory like that.
Post #251354 29th Mar 2014 11:06am
Gremlin
It was raised when I picked it up, well when they delivered it to me, but because I use the car for my chauffeuring buisness I had to take in right away It is going in on Tuesday and I have told customer services. Let's wait and see
Post #251413 29th Mar 2014 4:44pm
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
That's appalling. I'd reject without hesitation, the quality assurance dept for land rover must be full of blind workers. That's truly awful.
Post #251429 29th Mar 2014 7:49pm
JAYBOY
Thats so bad for 120k car to be delivered in that condition.
Bad bad quality Mad Mad 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #251430 29th Mar 2014 7:53pm
Vogue
Yes it doesn't look right and no it definitely isn't acceptable, but come on get real it's only a door out of alignment and can be adjusted by just slackening the hinge bolts off and realigning - rejecting it for something so minor I doubt will wash with LR or even in Court, any Barrister would just argue that they should be given reasonable opportunity to correct it. It's not as if the engine had blown or the chassis was twisted Thumbs Up (you hope Wink )
Post #251434 29th Mar 2014 8:02pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
HI I just took a look at my rear door it too is slightly out of alignment how ever if one was to realign the door then it would not line up in the upper part of the wheel arch area. there may be a little bit of adjustment possible. However I don,t think your door will be able to be realigned with that much of a miss match you may need a new door. It seems JLR might have a problem with door pressings being made.
Post #255647 23rd Apr 2014 12:19am
roverhaul
United States 2011 Range Rover Autobiography Supercharged Santorini Black
Maybe it's a 14.5 feature - Asymmetrical door trim as part of the Not Quite Right package?
I have the same thing on the LHS passenger door trim on my MY14.5 SWB. The passenger door is "normal" but the trim on the LHS is clearly higher and looks like the first picture in this thread.
What's going on, on the LHS that's different from the RHS?
Post #255649 23rd Apr 2014 1:26am
