![]() | Home > Technical (L322) > Unlocking All Doors with Drivers Door? |
IIRC there isn't unless its hidden in the CCF and i've missed it but i think that locking section covers using just the fob and drive away locking. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6766 ![]() ![]() ![]() |
IIRC, this is the designed behaviour and can't be changed. I believe it's for added security to avoid car-jacking, by someone opening the passenger door as you get out the drivers door. Got - 2017 SDV8 Autobiography in Loire Blue
mach1 Member Since: 11 Jan 2014 Location: London Posts: 21 ![]() ![]() |
Blimey! Thanks for the quick replies.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
sounds like you have 'auto lock' enabled...do the doors lock automatically at around 15 mph?, if so then the dealer can switch this off .... the iidtool does this as well but you'd have to check with the gap chaps.. ... - .- -.
IID can do that Stan, but it's only auto-lock. Nothing can do auto-unlock.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3787 ![]() ![]() |
with a 2012 you can turn off drive away locking in the dashboard controls (its in the manual). You cannot though set it to open all the doors from just the drivers door handle. Only solution is to disable the drive away locking, but that measn all the doors stay unlocked - not good at traffic lights with a handbag or laptop on the seat.
opposite to you Alan, mine had it enabled when i brought it and i got fed up with having to pull the handle twice, and passengers that didnt know this would have to be told how to get out... ... - .- -.
Safer in Glasgow to have all your doors locked Stan! |
I'm living in Camberwell. I think I'll keep the auto lock option enabled! |
at least you know that you can switch it off...
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
If I've got passengers, I just press the button under the hazard switch. I don't always remember to do it though! |
