Home > Technical (L322) > Fuel Burning Heater - Runs Cold |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 |
How much fuel do you have ? |
21st Jan 2009 4:14pm |
SHC Member Since: 21 Jan 2009 Location: London Posts: 5 |
A full tank or at least 3/4.
21st Jan 2009 4:18pm |
Not that then |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
perhaps its linked to your smell of fuel... |
21st Jan 2009 5:02pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
could be wrong but there is a sensor inside and outside the vehicle that measures temp so it heats up acordingly if you have a duff sensor that could be your problem or check the fuses onto no6 Range Rover
21st Jan 2009 6:50pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Here's something you should consider (and I don't know if I am right or not) but I have a feeling the proper fuel burning heater was not standard when your car was made. I think that the timer only gets the fans going to ventilate the car on hot days for example.
22nd Jan 2009 12:14pm |
You see thats why forum's are great you learn every day |
22nd Jan 2009 1:28pm |
I copied this text from the RR L322 Workshop Manual:
22nd Jan 2009 3:03pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 769 |
Probably different systems, but we had a similar symptom on a Mercedes van and the fault was with the FBH water pump that had to be changed. |
22nd Jan 2009 8:03pm |
dark.soul999 Member Since: 04 Feb 2009 Location: Bucuresti Posts: 9 |
The FBH its located on the passenger side (below battery). When running a “fan/blower” noise its heard in this zone. If noise stop after few minutes (after activation), FBH its defective. Go to dealer workshop to investigate cause. |
5th Feb 2009 12:03pm |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
When was this a standard fit then? I'd like to know if ours has it, although we won't know till the weekend when we pick it up |
24th Feb 2009 1:35pm |
use the vin number and ring a dealer, they should be able to tell you Discovery 4 HSE
24th Feb 2009 2:21pm |
Just went out and had a play:
2nd Mar 2009 12:07pm |
