Home > In Car Electronics (L322) > The most ANNOYING thing about my L322 (pictures) |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4994 |
great !! All my spelling errorz are belong to me!
20th Mar 2014 7:45am |
Yes, someone was on drugs when they came up with that design.
20th Mar 2014 8:04am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I didn't think the 2012 Range Rover was back compatible with Venture cam ?
20th Mar 2014 11:33am |
GregMilner Member Since: 08 Sep 2013 Location: Perth Posts: 54 |
I guess you're right mzplcg (jeez I wish I knew your real name. Try typing that nickname when you've had a few Becks and a lie down). I just get lazy, and go for the easy, no-extra-wiring solution; which is what LR should have done years ago:-)
20th Mar 2014 12:12pm |
if I know Axle….that's certainly what Cecil at Barbagallo gold me yesterday. He's the guru in these matters, I'm told. But that's what I was told, you have to have all the VentureCam bits fitted at the point of ordering, and THEN order the VentureCam as an option.
20th Mar 2014 12:18pm |
…but then, it's a magnificent vehicle. I'm only being grumpy about the little things. It's a First World problem:-) 2012 L322 TDV8 Luxury
20th Mar 2014 12:20pm |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 |
This is an alternative (and an more expensive option) when ready to be released
11th Apr 2014 7:03am |
There is a small issue with TrailAir as I discovered a while back. It only effects the L322 and then only the top spec variants which have the external dipping mirrors (photochromatic dimming for night driving)
11th Apr 2014 8:19am |
I think this is a brilliant solution with the old phone/suction bracket. Most of us have older smartphones lying around (I have a Galaxy S that is currently not used). I understand if you have the time and inclination to do a second camera it is a good idea but I am also one of the quick and easy fixes where it makes sense MY 2010 5.0 SC Galway green and sand interior!!
11th Apr 2014 9:01am |
==================================== "Open Mike Night " sounded like a lot of fun until i found out i was going to an Autopsy |
11th Apr 2014 12:13pm |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 |
Are you Jeremy Clarkson!!??
11th Apr 2014 12:31pm |
Wrecker79 Member Since: 15 May 2014 Location: Reading Posts: 84 |
@MZPLCG - Can you tell me how, please? I've fitted the cradle, plugged it into the existing connected fitted to the wiring that was taped back to the loom, put in the charged VentureCam, and enabled what I think I have to in the CCF using the "Software Download" part of SDD - but no joy! The companion/venture camera part of the 4x4 info fires up, and I even have the choice of four channels of blackness, but nothing - whilst there is 12v on the back of the cradle, it never seems to get to the spring-loaded connectors on the back of the camera, and therefore I cant register the camera and that is that! I'd really like this working for when I am reversing the boat down a slipway, and it was one of the few options this otherwise perfect car did not come with! Any help you can offer would be appreciated! |
30th Aug 2014 4:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35315 |
'in the CCF using the "Software Download" part of SDD '
30th Aug 2014 4:52pm |
Hi Stan,
30th Aug 2014 5:08pm |
