Home > Technical (L322) > Sunroof Not Working
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Sunroof Not Working
Has anyone come across a sunroof not working? 12v at the fuse but no movement, maybe a very slight tick momentarily after the switch is operated.
Tried holding the switch to the rear for 40 seconds, to the front for 40 seconds and pressing the button in for 40 seconds but no movement.
Maybe a goosed ECU? 2002 Vogue Epsom Green with Ivory Leather.
Discover 2 V8
Discovery 2 TD5
Discovery 1 V8
Audi S4 (2005)
Audi S4 (2000)
Post #169817 3rd Feb 2013 9:12pm
RR2008HSE
Big Cry
You've got me. All I could suggest was holding the buttons and you've already tried that. Question
Post #169858 4th Feb 2013 6:19am
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I've now got the same issue, and have a rear window that has been doing it for a while (clicking under passenger seat when button pressed). I think it is the ECU that is starting to fail, bit by bit. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #249078 18th Mar 2014 8:40pm
I guess first job is to get at the power connector on the roof motor and try it direct from a battery. This will help to determine whether it is sunroof or somewhere before sunroof.
If it opens this way, hopefully it will close too Big Cry .
Post #249091 18th Mar 2014 10:03pm
Could well be the motor... I have changed a few Shocked Only held in on three screws Thumbs Up
Post #249107 18th Mar 2014 11:09pm
Flashman
Good points will try them. Thanks! Tom
Current Drive
Previous Drives
Post #249109 18th Mar 2014 11:17pm
