Home > Maintenance & Mods (L322) > transmission oil/filter change |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
hi, has anybody used the britpart filter on a td6 with gm box,i am going to change the oil and filter and was wondering the best filter to use |
15th Mar 2014 11:23am |
Best filter is a genuine Land Rover filter from Dan at Duckworths... |
15th Mar 2014 1:06pm |
i have sent a email to duckworths but had no reply yet. |
15th Mar 2014 10:09pm |
arron Member Since: 22 Sep 2010 Location: lincolnshire Posts: 123 |
oe filter for the gm box is filtran, last time i priced one from lee at duckworths in kirton was over £100. heres a link to some one selling the original filter and gasket for half the cost.
15th Mar 2014 11:34pm |
thanks for your help i will buy the filter on ebay,noticed they do the oil as well in a kit ,is it dextron 111,is this the right oil |
16th Mar 2014 1:28pm |
after i had my gearbox rebuilt the guy who did it condemned the type of oil gm specified and said its only a standard dexron 3 and should really be a full synthetic instead, since the rebuild i run mine on the oil he recommended and to date is nice and smooth. although it should be as it only been on just over a year, only time will tell. if i where you i would be inclined to get some full synthetic dexron oil and flush it a few times then keep it on the good stuff, synthetic oil in my opinion can only help the gearbox and hopefully keep it trouble free. |
16th Mar 2014 11:50pm |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Shouldn't oil be Dextron VI (6) |
17th Mar 2014 4:54am |
i thought dextron V1 was for the 6 speed box,millers recommend millermatic atf sp lll ws code 6213, this oil is getting to be a minefield. |
17th Mar 2014 10:14am |
This is the correct oil. Texaco ETL-7045E. But from a list that was about some time ago Dextron VI can be used if licenced by GM. Dextron VI superceeds all previous Dextron's ( III, IV etc ) |
17th Mar 2014 4:30pm |
changed the oil and filter today,thanks arron for the filter link ,i used millers oil ,i rang there technical department and they had a choice of 2 ,the job was really easy took about 2 hrs . |
22nd Mar 2014 5:55pm |
