Home > Maintenance & Mods (L322) > Transmission oil leak
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
After a two day battle to change the transmission oil cooler... ( should have known that having pulled off the two oil pipes that after 11 years, they would not seal properly again when put back on ! ). So two new pipes on today and thats the job complete. Have also changed the oil cooler thermostat and back plate at the same time.
However, have noticed that the leak on the back of the gear box ( part furthest away from the engine, is getting steadily worse. Had a new transmission box filter and oil change 9 months ago and used a new gasket but with out any other extra sealant. Oil seems to gather at the bottom of the round casting at end of box and then drips on to cross member underneath. Any ideas any one ?
Post #248465 15th Mar 2014 4:41pm
Check the breather pipe is not blocked
Post #248506 15th Mar 2014 9:08pm
DaveK
Can you direct me to the location of this pipe please.
Post #248568 16th Mar 2014 10:10am
DaveK
Pretty please any one ?
Post #248938 18th Mar 2014 11:10am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
http://www.rangerovers.net/forum/6-range-r...lines.html
The black pipe with the 'u' shaped bend at the end.
It's tucked over the back of the engine above the transmission, you would probably have to remove the air intake scoop for the heater/blower to see it.
Post #249253 19th Mar 2014 9:45pm
DaveK
Cheers...I'll get me spanners out again then !
Post #249328 20th Mar 2014 9:16am
