![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8363 ![]() ![]() ![]() |
They were pattern ones and very hard plastic not rubber like the originals....
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Cheers for the heads up mate and keep the progress reports coming! |
Just been changing the piston ring on the air suspension compressor as it was slow to raise, well the reason for that was evident when I pulled it out of it's rats nest of an abortion the LPG fitter did....
Both times I've had to change front air struts were after having it all the way up for any length of time. Worth keeping a look out. |
Cheers Paul I'll keep an eye on them, they have been changed at some time, they don't look 12 years old so hopefully be OK for a while...
Keep em comin!!! |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
You are a complete car nut. I highly respect this kind of mental illness.
I blame you for my job list getting bigger!! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
Great write up Pete, reminds me of my Defender Write up on the other forum, very meticulous and caring. Discovery 4 HSE
Harris Member Since: 02 Apr 2013 Location: Northants Posts: 155 ![]() ![]() ![]() |
Love the write up it is motivating me towards some of those niggling little jobs |
How serious are looking at taking the laning as ther are some bits you really need to get for the FF that are up for grabs but would need a drive for you to pick them up |
FYI you may find when starting if you hold the LPG changover button down, the LPG system will cut in and take over, helping reduce running costs even more |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
Most LPG systems will do this, but I was advised that it is a good idea to let them start on Petrol normally, as this lubricates the valves each time you start up. Was also advised to let the FF run on petrol for an extended time maybe once a month or so for the same reason (this also exercises the petrol injectors etc.) |
I found it ok as long as the odd run on petrol was done so what I did was keep about an 1/8th of a petrol tank unless I was going on a long run and then once a month or two run it right down so the petrol didn't go stale as I was running v power back then |
