Home > Technical (L322) > Td6 battery
joebenz
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Td6 battery
Yesterday I went to start the car but when I put the key in the ignition but the key wouldn't turn!
To cut a long story short I called out RAC and they said I'd been given a 95v battery but needed 110v battery! Can I just buy one and replace it? He mentioned something about reprogramming the computer to accept the battery!? It's a 2004 td6.
Post #248262 14th Mar 2014 12:21pm
Your car should start quite happily with a 95Ah battery, the 110Ah version just gives you a bit more reserve in colder weather.
I think you need to put your battery on a charger and then investigate why the battery discharged.
Despite what the RAC gentleman said there is no inter-link between the battery and any ECU on the car that needs reprogramming.
Whether such a feature is present on more up to date cars, I have no idea.
Post #248263 14th Mar 2014 12:31pm
mjdronfield
My genuine Land Rover battery is 110 Ah, and I'm pretty sure thats what it says in the manual.
As above though, should still start with a 95Ah though, just not much scope for any other issues....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #248274 14th Mar 2014 2:40pm
Surprisingly the Vehicle Handbook quotes the battery size as 90Ah or 110Ah.
Personally I would have thought 2x110Ah would be more appropriate. Smile
Post #248278 14th Mar 2014 3:13pm
Is this a key not turning issue as opposed to a battery issue ? .
Post #248290 14th Mar 2014 3:57pm
joebenz
He tried disconnecting the battery and resetting it the key still wouldn't turn. When he used a bigger battery he had in his van the key turned fine? Land rover quoted me £212 to supply and fit a new battery and they say it should be a 110v.
Post #248333 14th Mar 2014 6:17pm
mjdronfield
I'd just go with the supply bit, and fit yourself..........at that price 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #248335 14th Mar 2014 6:30pm
SteveMFr
Site Sponsor
As others have said, you should be fine with a 95Ah battery (if you manage to find a 110V battery and install it, you'll be having other problems Laughing ).
Your RAC man may be getting your older L322 confused with a newer one - they profited immensely from a software update to adjust the alternator charging curve.
You can either go to the dealer and start throwing money at it or have someone who knows what he is doing check to see exactly what the prob is. If your battery is older, it may well need replacing (you don't say when you were 'given' the 95Ah battery). If the battery is relatively new, I'd look for other problems. There are many possibilities on an L322...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #248337 14th Mar 2014 6:50pm
