Home > Technical (L322) > Rear Wash Issue
mick-ne
England 2004 Range Rover Vogue 4.4 V8 Java Black
Rear Wash Issue
I have been in the car today testing the functions of everything as the car is new to me, I have discovered I have no rear wash or wipe function also no headlight wash. I have checked the obvious first as in fuses and connections at pumps which are both brand new as just finished a facelift. Any suggestion would be welcomed as I don't want to miss something obvious. Thanks Mick
Post #247273 9th Mar 2014 8:05pm
mpirie
Can you hear the pumps running when you push the wiper stalk forward?
If you can then i'd start looking for blockages in the pipes. The rear is particularly bad for blocking since its rarely used.
If you can't then time to check fuses and pump motors.
Mike
Post #247411 10th Mar 2014 5:45pm
stu
the headlight washers will only work with the headlights on and something like every fifth squirt of the window wipers the headlights get a squirt.
if you open the upper tail gate you will see three 10mm from memory bolt heads, these secure the spoiler. then pull it rearwards, its like a key slot to actually remove it. be carefull as the camera wires are there and you need to only move it a bit and I usually turn it over onto the roof.
then you can get better access to the wiper. you need to get a pin and clear the two nozzles out, then ull the cap back to expose the water pipe, squirt the water and see if it comes out the pipe. if it does it was just blocked nozzles, if not there is info on here about non return valves etc which will be your next port of call. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #247823 12th Mar 2014 6:23pm
Cloned earl
England 2002 Range Rover Vogue 4.4 V8 Adriatic Blue
Have a look here for the rear wash/wipe issue
http://www.fullfatrr.com/forum/topic884-15.html Previous LR's
Series III x2 SWB
Defender V8 90
Range Rover Classic V8 3.9 x2
Range Rover Classic V8 3.5 efi
Defender TDI 300 x2 90/110
Freelander V6
Defender TD5 110
Discovery II V8 LPG
Post #248065 13th Mar 2014 2:55pm
mick-ne
I had a little time today so did a bit test work on rear wiper. The correct feeds and switched earths are as they should be, I was surprised to find the rear washer pump is switched from the rear wiper motor I can only presume the motor or ecu is the problem.
Post #248177 13th Mar 2014 9:38pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I had no washer on the rear, but others were working. This is how I fixed mine:
Removed centre interior trim on upper tailgate, it just pulls off as it has metal spring clips. remove hose from lug going into motor, put hose in gutter and activate washer to make sure there is flow. If so the nozzle and interior of the wiper is clogged. I attached my car tyre inflator to the lug where the pipe went and turned it on, after only a second or so brown water and Censored came out of the wiper jet nozzle.
Refitted the hose, activated rear wash and hey presto it worked a treat Very Happy Thumbs Up 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #257750 5th May 2014 1:00pm
