Home > Technical (L322) > Front bumper removal
funnyguy1
United States
How difficult is it to remove the front bumper (for painting)? Are there any diagrams showing how to do it?
Couldn't find any on youtube. Thx! Mike
Post #248082 13th Mar 2014 3:30pm
Googsy
As it happens im doing mine at weekend. Firstly open the bonnet and remove front grill. Also on inner wing liner each side you will see a bolt these need to be removed. Then you need to get underneath and remove the bolts that connect the undertray to the bumper. Once grill is removed there are a number of philips large head type screws that hold the bumper on. Once all these are removed you need to pull the bumper out from the side and pull forward. I would suggest having a second person hold the other end and have something soft like an old sheet underneath to rest bumper on . Be careful when removing as you need to disconnect the washer jet hose the parking sensor loom and the fog light loom. If you pull bumper away too quickly you risk damaging these connections otherwise. Hope that makes sense but its pretty easy really. Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #248104 13th Mar 2014 4:57pm
Chauch
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
It is very easy - there is a thread on here if you do a search with a diagram showing the location of all of the screws (including a couple that were not obvious).
Took me about 15 mins or so... 4.2 Supercharged Vogue SE
Post #248157 13th Mar 2014 8:24pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
............and 3 hours to get it back on........... Rolling with laughter 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #248164 13th Mar 2014 8:39pm
Chauch
LOL - I actually surprised myself and it took less time to get it back on (although I did replace two screws as they were corroded). 4.2 Supercharged Vogue SE
Post #248166 13th Mar 2014 8:42pm
funnyguy1
United States
Hi Skot, Why so long to put back on?? Is there something I should be aware of?? Thx! Mike
Post #248187 13th Mar 2014 10:17pm
SKOT
No, it's a pretty simple job by all accounts.
I am known here for my total lack of any skill or luck surrounding anything remotely technical........ Big Cry 2006 4.2 SC
Post #248188 13th Mar 2014 10:19pm
SKOT
I'm very good at watching other people do it for me and chipping in with the occasional piece of technical advice though...... Thumbs Up 2006 4.2 SC
Post #248190 13th Mar 2014 10:21pm
It's about ten screws that hold it on, surprisingly easy.
It will look like this: Shocked
 Discovery 4 HSE
Post #248230 14th Mar 2014 9:06am
