Home > Technical (L322) > PAS Fluid reservoir
dalziel
2003 Range Rover SE Td6 Epsom Green
PAS Fluid reservoir
Help! Steering is too stiff once underway and sometimes when moving off so thought I'd check PAS fluid level and condition. Went to spot by Windscreen washer reservoir and coolant header tank - NOTHING! Just two bolt holes where a reservoir could/should have been fixed! I'm stumped - where is the PAS reservoir if not there?
Post #248085 13th Mar 2014 3:48pm
RichTD6
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Hi, did you find it yet?
Not sure if its in the same place on all TD6's but on mine its a large black plastic cap which sticks through the forward engine cover about 3 inches forward and to the left of the diesel filter.
Hope this helps. 2012 Westminster TDV8 4.4 Indus Silver
GAP IID Bluetooth Tool
Previous Range Rovers:
2005 L322 Vogue SE TD6 Zambezi Silver
1995 P38A HSE Epsom Green
1988 Classic Vogue EFi Cassis Red
1973 Two Door Tuscan Blue
Post #249392 20th Mar 2014 2:10pm
